1993 Evinrude 40 HP
largemouth
The other day my boat would start right up,but cutoff at low idle speed. Finally boat took off running 6mph at 2800rpms at full throttle. After about 5 minutes speed increased to 21mph at 5400rpms. Problem did not reoccur the rest of the day.When I returned home I replaced the fuel filter, spark plugs( NGK BR8HS, gap set at.030) and spark plug wires. Carbs were cleaned out 2 weeks ago.I have not run boat since making these repairs.This is a 40hp Evinrude 1993 model on a Suntracker Bass Buggy.This problem occurred the last 2 times I had the boat out. Any ideas what could be happening?
steelespike
Re: 1993 Evinrude 40 HP
How did the plugs you took out look?<br /> When it increased speed did it do it like you turned on a switch?
Cwyatt
I have had a similar problem with an Evinrude 25 hp for a couple of years. I finally got a manual and borrowed an ohm meter and found I have a bad reading on the charge coil. When it heats up it acts fine, but when cool doesn't fire. It's a cheap part but I haven't been able to get the flywheel off! I just put up with the problem for the first 10-15 minutes of operation...does make you wonder when you are heading out into big water though.
