1993 evinrude no idle
patgm
I have an 1993 evinrude 60 hp vro model#TE60TLENE.It has ran a little rough the last 3 time out but the 3rd time it started ok and idled ok at first.About 3 hours later it did not what to start at all and then after i got it started it would not idle. I have put new spark plugs and fuel filter.I have been told it is probably my low speed jets,then probably ignition.I usually run the fuel out of the carbs before putting up the boat.It usually does not sit over 2 months at a time. Pat
Philby
Re: 1993 evinrude no idle
With VRO don't run out your fuel. The pump will still take up oil 'til the gas runs out. result is oiled plugs etc.
