Finally got time to check out my TPS. Found with the help of Dukedog's (Thanks!) factory manual that the TPS was at .631vdc @idle and 7.52 @ WOT. So I tweaked the TPS down to .292 @ idle (just to leave it a bit on the richer side) and still get a good 7.5 @ WOT. The engine does start and accelerate great out of the water with water muffs on it and maybe doesn't seem to smoke as much now either. I also checked for smooth consistent voltage values from idle to WOT, all good cold and hot. We will give this a try. BUT actually my original issue was that the engine would shutoff sometimes after a longer hi power run. Now it would restart immediately but would shutoff again once you move the throttle up any amount, and possibly repeat this 5,6,7 times before it would stay running with a little throttle input (maybe heat soak issue from the long run???) so this is why I was focussing the the TPS. If this doesn't help any i'm thinking look at the idle stabilzer circuit next....... thoughts?
