1993 Mariner 30hp, ignition key off won't stop engine
MrOtto
I have a 1993 Mariner 30hp with a Quicksilver remote controller. Outboard has electronic starter. When I turn the ignition key off, the engine still runs. What usually is the problem and where to start looking for ground issues? I tried to replace the ignition switch assembly, but did not fix the problem, and the aftermarket part had a terrible quality key barrel cylinder that stopped working, so I put back in the original one.
markhodges78
Yup to kill engine you need to apply ground
With your switch off check and make sure you have continuity between Black and Black/yellow at the switch
( not Yellow /black) also go back to the motor and find your Black /Yellow going into switch box and make sure it has continuity with switch off thus is what kills the engine
