1994 Fiesta Vee 265 Rinker water in cabin
jills
Any insight to cause of water in the cabin of the 265 Fiesta Vee. I have looked on line at other like boats and the carpets all appear to have wicking up the side of the galley floor. I am not sure if it runs from the engine compartment to v of boat as it fills up with water from some where. Does anyone have any ideas or similar problems.
mvn
Re: 1994 Fiesta Vee 265 Rinker water in cabin
verlew
Yes, water can flow from the engine well into the cabin on the Fiesta Vee 266. You can determine if the engine well is the source by examining the water for oil, engine grime etc. Water entering from the hatch should be relatively clean.
At the beginning of one season I took my boat out and noticed I was taking on water. I lifted up the engine hatch to find the engine compartment half full of water, so I immediately headed back to the slip. When I lifted the boat onto the boat lift, water that was in the engine compartment flowed into the cabin. (The fellow who winterized the boat had removed a fitting to the hot water heater and failed to replace it, which was the cause of the water intake).
Also, the Bowmar hatch on these boats are know to lose their seal. When I opened my boat this spring, I had 15 - 20 gallons in the cabin that could only have entered the boat via the hatch (and verified by the wet headliner around the hatch).
Rinkers are not very dry boats, and mine has been a source of minor annoyances since my purchase new in 1996. My rear hatch, front hatch, restroom, and rub rails all take rainwater in. They could've done better.
rinker265
Oh Baby does the 265 leak water. I bought the boat 2 yrs ago. When i 1st put the boat in the water there were no signs of leaks exept the side windows. Later to come back to the boat and find the cabin filled up with water. Pulled the boat out and had it looked at . Replaced the bellows. Put the boat back in. Same thing cabin filled up. Found that the shift cable boot was leaking as well. 3 starters later on a trip and the boat was pooring water out of the side due to a lower circulating pump hose. Yep changed the starter again. I have installed a water alarm system for this boat now. Seems to be water tight.check every crevis of the boat. Good Luck
