1994 Force (Mercury) 40hp
joho5
Just bought a boat and it has 94 force by mercury on it. The only trim that works is a rocker switch on the dash. The throttle handle has a switch but doesn’t do anything. What would I need to check to get that working?
Also there are the two green and blue wires inside the cowl that aren’t hooked to anything…just make barrel connectors on them. What can those be used for?
Thanks!
saltchuckmatt
Thanks!
You would test the switch but I'm guessing it doesn't work.
Blue and green are trim wires....blue for sky (up) green for grass (down).
Maybe someone thought the wire harness was bad. Locate the trim relay and see what wires are on there. You can most likely test your stock trim switch with the wires under the cowl.
joho5
The two wires that come from the control harness that are under the cowl…what do I hook them to?
saltchuckmatt
Normally they hook to the trim relay.
Here is a video of relay replacement.....look near the end on where they enter the motor. I think you will find someone spliced different wires into the relay.
joho5
This is maybe aftermarket wiring. There is nothing trim related under the cowl. The switch sends wires to back of boat straight to motor. Im assuming and hoping there is some relays somewhere. Need to investigate further.
saltchuckmatt
There's always relays and that's what those two wires do unless you have an aftermarket trim and tilt. Post pictures....under cowl and the t&t system.
joho5
I’ll take some tomorrow. I’m afraid they wired the switch straight to battery and straight to motor…which in theory wouldn’t last long.
I’ll take some tomorrow, but I don’t think there is any relays in there.
If I have to rewire from scratch, what will I have to do to add relays?
joho5
From what it looks like, there are two wires tied to battery that head to console to the switch and then from there back straight to the trim motor. I don’t see any breakers or relays. And the green and blue wires inside the cowl they come from the harness, are connected to nothing.
jerryjerry05
Part 2
9BRACKET Relay
F685948
Unavailable
10WIRE ASSEMBLY
F691908
Unavailable
11NUT (#10-32)
F1513
In Stock​
Ships within 24 hours if ordered before 3:00PM EST Monday-Friday.
" data-title=" " data-content=" " data-original-title="" title="" style="box-sizing: border-box; background-color: transparent; color: rgb(55, 119, 188); text-decoration: none; outline: none; font-size: 11px;"> In Stock
$2.90
$2.84
Add
12LOCKWASHER (#10)
F1975
In Stock​
$1.20
$1.18
Add
13SCREW (#10 - 24 x .750)
F1648
Ships in 2 to 3 days​
Expected in stock Nov. 1 - 2
" data-title=" " data-content=" " style="box-sizing: border-box; background-color: transparent; color: rgb(153, 153, 153); text-decoration: none; outline: none; font-size: 11px;">Ships in 2 to 3 days
$1.90
$1.77
Add
14CONNECTOR Splice
F662874
Unavailable
15WIRE ASSEMBLY (Green)
F662636
Unavailable
16WIRE ASSEMBLY (Blue)
F662908
Unavailable
17SCREW (.312-18 x .875)
F1822
In Stock​
$2.90
$2.84
Add
18LOCKWASHER (.312)
F8096
In Stock​
$1.70
$1.66
Add
19WIRE KIT
FA663744
Unavailable
20RELAY
F660917
In Stock​
$40.58
$39.63
Add
21BREAKER Circuit
F510460
Unavailable
22BRACKET Circuit Breaker
F91446-2
Unavailable
23WIRE ASSEMBLY
F664636
Unavailable
Need Help Finding Parts?
