1994 Tigershark fly wheel removal? (Tight working space)
thsp
I have a 94 tigershark. 640cc jetski. I'm trying to replace the starter gear assembly. But the flywheel is in the way to clearly has to be removed. My only prob is there is aprox a 6inch gap between the flywheel and the gas tank so it's a really tight spot to work. I'm new to this so I tried removing the gas tank then found out through research that I would have to remove the engine to get the tank out any way. So does anyone know a way to get the fly wheel off with only 6 inches of room. Can't find a puller to fit! :confused:
Re: 1994 Tigershark fly wheel removal? (Tight working space)
Ayuh,... Welcome Aboard,... My guess is,.... yer gonna be pullin' the motor...
shagy959
pull the motor faster easy and your back will thank you
Leardriver
I just did that procedure on a Kawasaki 1100 STX. Very little room. Four bolts and a few plug-ins to lift the motor, put a block of wood under the front, and now the motor is angled up at a 45 degree angle with the flywheel staring at you.
It is probably possible to not pull it. I am not nimble, and I cut easily.
