1995 60hp Power Tilt Trim Conversion
Holden1
I have a 1995 60HP Johnson (J60ELEOC) with manual tilt. Is it possible/what would be needed to convert it to power tilt/trim? Could I just get a PTT assembly and swap out the assist cylinder that I currently have? Or would I need to exchange the entire midsection?
saltchuckmatt
After market is probably your only choice. Cmc....look them up.
Chris1956
Why not look on the parts list for both manual and PT motors, on a site like crowleymarine. If the triple clamp and the transom clamps are the same on both, you might just be able to add the PTT module.
