1995 Chaperral 1930ss Drain plug?
Chaparral1930ss
Looking for a drain plug. I can’t find one for this thing anywhere, mine fell out unfortunately. Looks about 1/2”
The last picture is the one i found most similar to mine but it’s 1” and the one Walmart sells is different than the pictures. Great
It’s a 1995 chaparral 1930ss.
I use one of the emergency garboard 1/2” emergency plugs for now but it doesn’t fit as good as the original.
Anyone have one? Or know where i can get one.
Thanks
Yegboats
I can't remember 100% but I think this one fits. It looks like the same plug used on the Chap H2O's
I know the Chap drain plug uses the plastic retainer pieces, and this has a metal clip that hooks to the inside.
Chaparral1930ss
Wasn’t sure if I was going to get a response or not. Thank you so much for responding that does look similar. It’s worth ordering and giving it a shot. Thanks a ton. Will keep the forum posted if this works or not.
Chaparral1930ss
Ordered it. $22 shipping kind of expensive, total of $37, but I’m taking a wack at it as it’s my only option without having to use the emergency one, or installing a whole new transum drain.
Never seen any fiberglass boat with on of those, looks like the ones used on watercraft like my Seadoo, Yamaha
From the looks of the sealant around it, I'm thinking someone replaced it with that type. If the one Yag doesn't work, look at a local watercraft dealer
Chaparral1930ss
Update
: this plug worked! Thank you
airshot
For future reference, you can use one of the expandable rubber plugs in a pinch. They are availiable in various sizes and each size is adjustable quite a bit. Always carry a couple of various sizes for that unplanned emergency.
briangcc
That's actually factory - mine looks like that. At some point I have a bronze set to be installed as I've never liked the plastic.
