1995 Force
1/4Horses
I just purchased a 1995 Sylvan Pontoon boat w/this motor attached. Right below where you take the top cover of the motor, there is a peice of the casing missing. It has been backed up against somthing and has broke this piece off the motor. Will this affect how the motor runs? Should I cover it with something? It looks like tape has been over it in the past. How much would it cost to replace this part? Thanks for your help!
12Footer
Re: 1995 Force
The bonnets on OBs are not completely airtight anyway, so you should have no problems with it,unless it get's rained-on,or water backs up on the bonnet when cutting the throttle back..You don't want a wet CD ignition system.<br />Perhaps a good auto body repairman could fabricate a piece to go in there, or just glass-over the damaged area.It may look funky, but as they say, "It's better to feel good then to look good".
<br /><br /><br />------------------<br />Time to change my tagline
