1995 lund pro v se 1775 fuel tank
windshadow
hi doese any one know how to get the fuel tank out of a 1995/ 1775 pro v se tiller and how many gallon tank it is? the power head blew on my 1995 70 hp I think the vor pump stopped working. I am taking the motor in for a rebuild of the top end. also is anyone having problems related to the e10 fuel with the 1995 jhonson 70 hp or any of the fuel related items on the 1995 lund boats? thanks for any information on this matter.
sixmile723
Re: 1995 lund pro v se 1775 fuel tank
I have a 96 1660 pro v with 60hp johnson tiller. I can see a sticker on my fuel tank by looking through the rear scuttle hole, that says 21 gal. To get at the tank in my boat you take up the center floor panel. Why do you need to get at the tank?
And yes, I am working on an idle problem, motor likes to die at the worst time. Trying new fuel line, tank to motor, new filter, and new clamps at all lines. I had a small oil-fuel leak around the vro area.
windshadow
thanks six I called lund and they said I have a 32 gal tank, I am going to change to mixing my own fuel and oil.so I need to know how much fuel was in the tank when I fill her up. I have decided to drain the tank and put in new fuel lines for the fill and the motor.I will be picking up my boat today or tomarrow from the shop from a power head rebuild.I just want to make shure there are no leaks or anything going on under the floor .thanks for the reply bill.
windshadow
sixmile I pulled the floor board today the plate said 32 gal tank,thanks for info bill
