I own a 1995 17 ft Tracker Nitro with a Mariner 115hp, 4 cylinder; S/N - 0G175997. Before this condition I am about to describe the motor would run about 53 mph (gps) @ 5800 rpm. The prop is a three blade (22).
Recently, something change where I now can only run about 39 mph @4100 rpm.
I have replaced the spark plugs, spark plug wires, fuel filter; no change.
I have performed a compression test and all 4 cylinders measure 134 to 135 psi.
I have measured the resistance of the 4 coils, primary and secondary and they measure in range according to the Mariner Shop Manual. I have also measured the resistance of the Red Stator (Green/White to White/Green) @ 691.4 ohms.
I have measured the DVA voltages from the Red Stator and the Red Stator Adapter
295 @ idle and 320 @ WOT .
I have measured the DVA voltage output of the switch box to the 4 coils.
#1 195 @ idle 204 @ WOT
#2 195 @ idle 240 @ WOT
#3 195 @ idle 200 @ WOT
#4 195 @ idle 240 @ WOT
The kill lead reads 320 @ WOT.
So far, the only unusual reading is the output of the switch box to coils #1 and #3 are reading about 16 % lower than coils #2 and #4.
Would this difference be enough to prevent the motor from reaching 5800 rpm?
