Coolbreeze96
- Joined
- Aug 2, 2018
- 1
I'm working on a 1995 200hp mercury XRi, it runs great, but anything over 5000rpms after about an 1/8th of mile it falls back to about 4300rpms, doesn't cut off or anything. Now if I bring it back to neutral lay down on it, it will pick up for an 1/8th mile and do it all over again, have changed stator, trigger, coils, basically everything electrical, TPS, changed fuel pressure regulator fuel pump, high and low, changed fuel line bulb and run it from another tank, removed all electrical from battery except engine cables, unhooked voltage regulator, changed ECU cleaned injectors, holds 40psi, removed the oiler, hooked timing light to every cylinder doesn't fall when it drops rpm's, any help would be greatly appreciated please be my hero, lol no one local including myself can fix this thing, if u can point me in a direction I haven't been and fix thus thing u will definitely be the man....lol
