Hello fellow boaters,
I am posting here for the first time to see what kind of feedback I can get on my recent purchase. I just bought my first jet boat. A 1995 Sea Rayder F16 Mercury Sportjet 120hp. I am posting pictures and videos of for advice. I bought this as a project with little history of the boat. Below is what I know.
The boat was last used on a lake and apparently sucked up some weeds.
The boat starts and runs, but just wont really go anywhere. When the seller told me this, I'm thinking "Jet pump" I have experience with waaverunners :facepalm: So I get to the rear of the boat start tearing it down to see what damage has been done. Aside from it being old, impeller and wear ring look extremely clean. So I had the wear ring checked out and the measurements were fine and the clearance was fine with the impeller. So now I'm thinking, "compression." So I found this online
So I checked mine and came up with this...
1-120
2-150
3-150
4-135
Not the compression. So at this point I'm not real sure... So I get on the PC and look up other possible issues. Ride plate and "cavitation." Seems to be an pretty common issue, due to them being started out of the water. Sure enough I find this.
Sorry for the elementary terminology, I'm still learning
So I pull the ride plate and asses the damage. its bent down over an inch. So i look for a part online, never found anything. Call the sea ray dealer they want $460 + tax + shipping!!!!
I wasn't happy. So then I took the part up the road to a machinist to see about the possibility of it being bent back. Sure enough they were able to get it back. So I went home mounted this sucker and it's back flush the way it is supposed to be.
I'm waiting on some carb gaskets and pivot bolts (reverse plate) to come in before I put it out on the water.
So now that you are up to date on the progress... I'm wanting some advice on anything really but specifically the cosmetic issues. I'm going to do the seats myself, but when it comes to buffing vs painting over/ gel coat. I'm totally clueless. Should I have it painted? Could I do it myself? I have access to a paint sprayer and I have a compressor. Should I just buff it out? How should I go about it?
1-120
2-150
3-150
4-135
