WaterBoy76
- Joined
- May 31, 2018
- 2
Hello All. I'm a past I/O performance boater and just picked up a 1995 19' Spectrum with a 70HP Force outboard. It has been sitting for a couple of years, but is in pretty good shape. I am new to outboards so I some quick questions! The engine fired up no problem, but after about 20 seconds of running there was no water coming from the tell tale. I was using mouse ears at the bottom water intake. I'm going to try it again with the lower unit completely submerged. With the mouse ears, is it possible that the water was not being pushed properly to the impeller to carry it up to the engine? Also, is there a certain amount of time that will laps before the engine warms up enough for the thermostat to open and let water through for the tell tale to work, or should it be immediate. My brother has a Boston Whaler with a 70HP Mercury outboard and says his tell tale works immediately even with mouse ears. I'm not sure if the Force is different, but I'd like to try and test the engine properly before I start replacing the impeller or thermostat. Thank you for any help!
