1996 140 Tohatsu - Bad Cylinder - To Rebuild or Not To Rebuild ?
jetboy12
Long story short one cylinder is shot on my 96 140 Tohatsu (bad carb job - lean setting). I loved this motor up until now but I need some opinions on if its worth rebuilding (pretty low hours on motor before this happened). Full rebuild vs just the one bad cylinder ? Can I tear apart and have a shop redo to save some labor ? Do the whole thing myself ? Start over ? Thanks in advance !
dtj
Re: 1996 140 Tohatsu - Bad Cylinder - To Rebuild or Not To Rebuild ?
Whats' wrong with the bad cylinder?..........Don
jetboy12
I haven't pulled it yet but it looks like a burnt piston/bad cylinder. Alarm never went off and I shut it down quick so it didn't get too hot.
pvanv
Check compression, pull the head and inspect. If the cylinder wall isn't too bad, you can hone it by hand, install new rings (and possibly a piston) and be running again.
jetboy12
Thanks ! Any tricks on pulling the head off ? The lower bolts are rusty. Also just the bad cylinder replaced or a complete rebuild ?
pvanv
Depends on what you find after you pull the head. On a motor of that vintage, a head bold might snap. In that case, you may end up with a helicoil insert for the offending bolt(s).
