I have an opportunity to purchase a pair of 1996 C/R 150 Evinrudes with 500 hours on the meters. One runs good but needs a power pack. The second has had the #1 piston break and score the cylinder. I plan on repowering my Mako 228. The seller states that a mechanic tore down the blown engine and said that #1 piston cracked and that pieces scratched the cylinder(s). He states that the mechanic said it is rebuildable. It is in boxes. I am retired and have the time to work on it.
The questions are: Were there any inherent problems with this model engine that I want to stay away from? Is this a project that sounds reasonable? Is it worth doing or should I keep looking? I am guessing around $500 should cover parts for the rebuild. Is this in the ballpark? Could this type of failure result in excessive unseen damage? He is asking $1500 for the pair including controls, gauges, props and oil tanks. He states that compression is good. If it is rebuildable, that sounds reasonable. He states that the lower units, etc are good on both. Are these good dependable engines?
I need opinions and also advice as what to expect.
Thanks in advance,
Bob
Thanks in advance,
Bob
