1996 Johnson recirculation hoses
Bareil
Hi all,
I changed the spak Plug on my "new" 35 hp 1996 outboard motor and saw that some plastic hose were melted.
Those are the recirculation hose I think.
​​​​​​​Want to replace them but do not know where to plug things.
There is 2 ports on each cylinder, but the top. There is a single tee remaining at the bottom to connect with the primer?
Primer hose seems to only be going to top cylinder.
The factory manual does not even show where the hoses go.----The primer valve only has one hose coming off it so it only goes to one location on the motor.----Oh----I have about 10 of these motors for rebuild / parts.----Your location ??
Bareil
I was able to figure it out. Using the part list. (See attached screenshot)
The #3 is the bottom cylinder and #1 the top one. Each cylinder has a both a check valve and an elbow.
The length in mm are also correct.
Thx for your help.
