1996 mariner oil pump plug kit
Fisheye-56
I found a thread here on the topic, bought the oil pump plug kit followed the procedures mixed my fuel and oil stared the engin. Low oil alarm blaring....what did I miss? The resivoir cap off and disconnected the sensor sitting on top of oil pump removed and unplugged. Any ideas where I went wrong? Thanks for any help.
Dukedog
you left tha "still workin" oil warning module on it....... get rid of it also.
Fisheye-56
It sits on top of pump right? It's been removed. It that's what your referring to
Dukedog
no, that's a rotation sensor.. its a black rectangle box 'bout 2 1/2" x 3 1/2".. follow tha two wires from tha oil tank cap back to it....
Fisheye-56
The module is solid state with theee additional wires after the resivoir cap and rotation sensor wires the other three,they go to other side of motor to two different terminals. I completely remove the module ? Right?Just a oil changing brake changing Mech. This is a little scary.
Dukedog
​yeah.. jus de-term all that originate from tha module and remove it.. you will also lose tha self check beeps when key is turned on..
Fisheye-56
Duke dog can't thank you enough. Will do tomorrow and let you know how it does....hope to be fishing this weekend now!!!
Fisheye-56
Did everything boat started great ran fine..till I put it in the water. Come out of the hole them loose power...still running but Boggs down. I went back and review the process.i didn't remove the oil line attached to the lower part of the motor. It was to be plugged? It that the problem? With the power?
