jthornton0604
- Joined
- Aug 5, 2016
- 3
Recently picked up a 96 Ranger R72, pristine condition, from a friend of the family. Basically sat in a barn and was taken on the water about 3 times a year. The motor is a Mercury 1996 115 ELPTO.
Last week I turned up the idle speed and changed out the plus because of the following issues:
Recently it has started to quit in the following situation. I run across the lake, full speed, idle down, turn off the motor. When I go to start back up it turns over, put it in gear, it dies. Sometimes I have to start it a few times before it will finally get in gear without any issue.
Issue 2 - It really seems to go through some oil, not at 50:1, seems to be more at 40 or 30:1. When moving slow I have smoke (quicksilver oil). Filled the oil, went through about a tank of gas and had to refill the reservoir again.
Any assistance is appreciated. Please answer as if talking to a third grader...my knowledge of engines is limited.
