1996 penta 5.0 fl. replace freeze plug.
Stanoglenn54
Sea Arrow 1996 penta 5.0 fl. Thats what it says on the valve cover. Engine was replaced a couple years ago ($3500) I assume with a rebuild but who knows what. One freeze plug was sitting below the engine. I replace the plug with a rubber one to make sure the block wasn't cracked and ran it. No leaks. It is the plug under the engine block right behind the fuel pump (front left). I had to shave about 30% off the thickness of the plug to slip It under the engine mount. I thought about removing the engine mount in order to put the a brass plug in but I was warned that it may twist the out drive and cause damage. Any suggestions will welcomed. Thanks Stan
Ayuh,...... Welcome Aboard,.... You gotta pull the drive 1st, then change out the core plug, realign the motor, 'n then reinstall the drive,.....
Scott06
Why not just leave the rubber expansion plug in there ? I had a freeze plug leak on a fresh rebuild on my 65 Pontiac 389, was a freeze plug behind the flywheel looks like it had a casting ridge in the hole. Its been in there over 25 years now hasnt leaked .
