Bluewater63
- Joined
- Jun 7, 2016
- 1
Have a pair of VX225 that I have went thru the fuel and all 12 carbs on both motors. Replaced main water/fuel filters and cleaned both fuel tanks. The starboard motor runs perfect but the port motor will run great and then loose rpm and shut down. If it stays under 3200 rpms it runs the longest. I plan on changing the needle valves in all 6 as there is a sheen of fuel in the water around it and to restart I have to open throttle 3/4 of the way and when it fires it has lot of fuel/oil burn smoke. I also have to pump blub before restart and sometimes it will not pump up, both are new and been replaced twice. Any other thoughts.
