1997 force 125 thumping
dave0120
My 125 has started thumping when under way. It is normal to about 3500 rpm then every few seconds it makes a audible bump as well as it seems to jerk a bit
las
That's what mine did! Worn clutch dog and gear.
Found this video that shows it pretty clear
las
Your welcome.
By the way it's not my engine in the video, just one I stumbled across when I had the same problem.
I hope you get it sorted! But it's not a small task no matter how you go about it.
If you end up changing the gears and dog you would have to shim the gears again and that requires a lot of special tools for the specific engine.
jerryjerry05
Is it a 125?? they didn't make a 125 in 97???
Some gear cases can be rebuilt without shim tools.
Just gotta figure out the model, year etc.
