1997 Mariner 75 trim pump
RNAbaja
Hi,
I have a 1997 Mariner 75 hp 4 cyl with the square trim pump.
I removed the 2 screws and pulled the pump.
When it came out the pump assembly is attached to the motor.
I have a replacement motor. Can I remove the pump assembly from the old motor and put it on the replacement motor? If so, how do I separate it from the motor?
RNAbaja
Hi,
I figured it out,
Remove the end cap of the motor and there are 3 screws holding the pump to the motor.
Remember to mark the end cap and the motor to insure correct re-assembly.
