1997 Mercury 115 HP 2+2 motor
Johnson110
I have 2 cycle oil leaking at the base of this engine after it is shut off, oil leaks then stops. Is there a seal that is bad what can cause the leak?
There is an oil recirculation hose that goes from bottom of engine to the top bearing area.---Possibly ruptured -----Look for it and replace it.-----That is my best guess from 1000 miles away.----I can not see / inspect the motor.
Johnson110
Ok so where can I get the OEM service manual for this motor serial 0G485647 115 EXPLTO mercury engine, Ebay does not have this serial number cannot find it any suggestions?
Johnson110
Ok then I will take the lower cowling off run the motor and see if I can pinpoint the oil leak!
mgjtkt
I bought one for a 1994 model from Mercury Marine. mine was about $90 7 years ago
Johnson110
Yes I have that number OG485647 115 EXPLTO , cannot seem to find one.
Johnson110
I got a manual and tighten the bolts down now I ran the engine for the first time on muffs after winterize. The number 2 cylinder plug is black, so I performed a compression test on the cylinders all 120 psi. The plugs have not been changed for 3 years they are NGK BP8H-N10, The cylinder all have good spark the number 2 plug is dry and black someone had used a heilcoil in that cylinder so I cannot switch plugs with another cylinder, could the plug be just bad tried cleaning it up and put it back in same thing cylinder missing
Johnson110
Ok so I got the spark plung thread insert off plug. How do you find out out what size thread the hole is in the block the out insert is messed up tried a m14 insert which threaded on to plug nice but will not thread in to spark plug hole. Please any help with this?
Johnson110
Is there such a threaded insert that has M14 on spark plug and M16 on spark plug head?
