MITCH WELCH
- Joined
- Oct 10, 2001
- 44
Outboard: 1998 carb. 150 VMAX. Problem: Engine starts and runs fine for about 8-12 miles and than it will surge a couple of times and back down from 5900 RPM's to 5100 RPM's. It seems to run fine at 5100 RPM's (after those couple initial surges), but will not climb back to 5900 RPM's for the rest of the fishing day. So far, these same symptoms have happend like clockwork on the last 4 fishing trips. My mechanic has replaced the stator trigger and key switch. Also, he's checked the compression, plugs, and gas. I've cleaned the filter and replaced the plugs. He said the engine computer would be the next step ($1000.) I've already put about $500. into trying to find the problem. Another $1000. would be pretty expensive, especially if it does not work. Any ideas or suggestions would be greatly appreciated. Thanks.
