1998 70hp mercury tracker, low compression
Privateer18
What would cause an engine to show low compression on the # 3 cylinder unless the carb is covered by hand?
Open or closed carburetor makes no difference on a compression test.--Something weird is going on here.------Serial # should be posted !
Faztbullet
It sounds like you have engine problems...pull the head and inspect.
Removing the exhaust plate ( 20 bolts ) allows you to inspect piston / rings.-----That would be my next step.
Reed valves have nothing to do with compression in the cylinders !
