1998 Evinrude 90 SPL WORTH
Status
Not open for further replies.
madclout
My boat has a 1997 90 hp Johnson SPL. I have a chance to buy another motor same year only an evinrude. The ad is as follows.
“Bought in 2017 had it rebuilt have paper work start and run had a miss took it to mid Kansas marina did scope compression is good cylinder 3 and 4 not firing has a short tilt not working should get all the cables. We bought a new motor there. MAKE OFFER need GONE.”
Compression readings are 105-110-100-100. These are not verified but what he said the shop told him.
He is asking $600 with controls. Is this worth it? If the motor is bad, is there such a thing as a core charge? Am I going to be out $600 or can I at least break even? New again to the boat game, spent way more on my boat than I wanted and am trying to possibly recoup some money.
Thanks in advance!
tphoyt
Personally I wouldn’t even be thinking about it.
6 bills for a 27 year old motor that’s not in good health is likely a bad plan.
Jmo
tphoyt
Not terrible but a bit low in my eyes.
If that’s what they really are. If you can’t check for yourself don’t believe it.
madclout
I can check when I get there, it’s about an hour from me. Sounds like I should steer clear
saltchuckmatt
My opinion...it kinds smells, that being said if you have the time and the knowledge check it out. Also, asking price isn't always the buy price.
If time is money to you, do the lower offer before you go.
Isn't yours the 88 SPL?
Either way, it's called rolling the dice.
Faztbullet
Sounds like whoever rebuilt it did not fix the original problem of why it failed the first time...$300-400 at best
oildriver
Thanks in advance!
The general consensus of a 97 v4 compression range is between 90 and 120. More importantly, your numbers are within 10 psi of each other. That is good enough.The other problems are easily fixed. Do your own compression test when you go. If the seller doesn't allow it, it's only your time and gas lost. If his #s are correct, it is a good deal.
Status
