1998 Four Winns Horizon with omc 3.0
FWTard73
Just did a engine swap and added a electrical fuel pump. The problem that I'm having is I can smell gas and the motor turns over but won't catch and fire up. Any help or suggestion would be helpful. Thanks everyone
FWTard73
Could this possibly be a bad ignition module as I have replaced the coil, wires and plugs? HELP PLZ
kenny nunez
Electric fuel pumps can be a real hazard if they are not wired through an oil pressure safety switch. Also be sure that the fuel is not coming from the carburetor flooding over from too much fuel pressure. Did you check if there is a spark coming out of the coil?
bowrider95
I have a 1995 Fourwinns with a 5.0 and I think I am getting to much fuel to the carb. I didn't have this problem until I replaced the fuel pump and the carburetor rebuilt. Does anyone know the fuel pressure from the pump? When cranking I see 5 lbs. of pressure.
