1998 Nissan NS25C3 oil seal and no reverse
mgriff64
Hi,
I am replacing a leaking and destroyed oil seal on my 1998 Nissan 25hp 2-stroke: the kit arrived with two seals, both the same prop diameter but one seal slightly larger. I tried the smaller one because the prop nut would not go all the way back on with the larger: neither seal fits very tightly and they only stop oil when the prop is on tight. Is the thrust washer the only thing holding the seal in? Do I have to run the prop to get the seal to tighten up? Lastly, I pulled the whole prop shaft, gears, and bearings out (all looks clean) but when I put it back in, there was no reverse. How do I bring reverse back?
Thanks
pvanv
Re: 1998 Nissan NS25C3 oil seal and no reverse
Sounds like you have 2 separate problems.
The correct LU seal kit (346873216M LOWER UNIT GASKET SET) includes o-rings for the inside and outside of the cam rod bushing, an o-ring for the lower pump housing, an o-ring for the prop shaft housing, gaskets for the pump housing, and 2 seals: one for the drive shaft, and another for the prop shaft. The seals are supposed to be a press fit.
The forward end of the prop shaft is hollow, and should have the push rod, steel ball, and a "spring holder". You probably dropped one of those pieces.
mgriff64
It turns out that part of the old seal was still in there but it looked like part of the housing. I chiseled it out and the seal fit fine. As far as the reverse, I think my incorrect placement of the seal worked as a shim and disappeared reverse. Thanks.
