1998 Volvo Penta 4.3GL - Fuel Pump not working...
Holt_22
Howdy,
Fuel Pump wasn't working, checked power, power is good. Replaced the fuel pump (low pressure) and still no fuel pumping. Any help on where to start would be appreciated.
Thanks
do you have voltage at the pump. not checking with a meter, however with a test light?
I_am_Sam
Howdy,
Thanks
Where did you check power?
Horigan
With a test light you clip the alligator clip to ground and pierce the positive wire near the pump connector with the sharp point of the light. 12V will light the light.
Holt_22
I checked the power of the connector to the fuel pump and the red/yellow wire. had 12v while cranking.
Swapped the relay also and nothing.
