1999 MERCURY 2.5 XRI 150 won't go to WOT
Gambler64
Motor died on me she was getting no fire on all 6 I took the kill wire off the front switch box and she fired right up. Boat runs good has full throttle in neutral or reverse but in forward gear almost nothing won't get hardly past and idle serial no# 0G144999 HELP!!
Faztbullet
Sound like you lost a switchbox or low speed side of stator...its running on 3 cylinders.
Jm072h
Would a bad stator cause it to run high rpms and move at about 5 mph with lost of power?
Faztbullet
Stator or switchbox will. Check spark on all 6 cylinders as they should jump a 3/8 gap with ease with a loud pop.
