Chad Hendrix
- Joined
- Dec 1, 2010
- 2
Subject-motor real cold natured and wouldn,t run at idle sometime.o.k. Motor has less than 200hrs on it.replaced fuel tank and primer bulb hose and fittings,still didn,t fix problem.next thing that was done was carburetor was cleaned by ultrasonic cleaner by technican and a water pump impeller replaced.next i took boat fishing and it ran hot,so i checked thermostat it was sticking and replaced it and same thing happened.again cared it back to technician and they replaced the upper head gasket and had to idle up motor a little. Again went to try out motor ,got up on plane for about 1/4 of a mile ,same thing motor quit on me .tried a few more times to run motor ,it cranked up only with the fast idle lever up.so i put motor on trailer and went home. I later took off cylinder head cover for inspection and noticed excessive carbon buildup on pistons and cleaned them and the water passages were clear in the cylinder head.what else good be wrong with my motor?
