1999 Suzuki DT150 compression
Pzandstra
I have a 1999 DT150 2 stroke. I was curious if anyone knew what the compression should be? All 6 of my cylinders came back between 102 and 110 and I'm not sure if that's ok or not.
robert graham
Sounds fine to me....rule of thumb is all cylinders should be within 10% of each other on compression. You could probably squirt some oil in each cylinder and run the test again and readings might increase. I doubt you have a problem.
Pzandstra
Ok. Good to hear. The shop I had it at thought that it was really low and the engine might be worn out.
robert graham
You could run a tank of fuel through the motor with a "carbon removal dosage" of 2 ounces of Ringfree per gallon of gas to possibly remove some carbon from ring grooves and loosen up piston sealing for better compression....
Pzandstra
I put can of sea foam in there when I filled it this last time. Not sure if that works as well
99yam40
If you did not do a shock treatment, it will not do much to help remove carbon from ring grooves
