1999 Suzuki DT150 ECU - Who Can Rebuild ECU's
cannis32
I have a 1999 Suzuki DT150S that has a bad ECU. Suzuki no longer makes this part so I need to have it rebuilt or if possible purchase a newer model ECU if they are interchangeable. I have had a hard time finding someone that will even look at, let along rebuild the ECU, everyone seems to shy away from Suzuki. Does anyone have any contact information for an electronics company that will rebuild Suzuki ECU's? Any help would be appreciated. Suzuki has me in a bad spot since they no longer make this model/year ECU. My boat is useless un
gm280
The problem "rebuilding" such a ECU is not so much the actual parts but the firmware that they used. Parts probably can be replaced, but it will not do anything without the firmware up loaded. So unless a person can down load the original firmware, if that part is not the defective part, how could anybody rebuild a workable unit again. JMHO
cannis32
So if these cannot be rebuilt, and Suzuki no longer makes an ECU for this model/year, what are my options, other than the obvious by a new motor? Can a newer model ECU be installed, does anyone have a used ECU? Looking for options.
GA_Boater
Try Ebay, Craig's List or marine salvage yards.
gm280
A couple of questions first. How do you know for certain that your ECU is bad? What is the engine doing or not doing? And did this just start or has it been going bad all along? Is the ECU burnt? Interesting to see your answers.
99yam40
can you give the complete model and serial number on your motor.
I might know someone that has and ecu. need to find out which one he has and what you have to be sure
cannis32
That would be awesome! Model number is DT150S. Serial number is 031029. Original part# 33920-92E80 which was superseded by part# 33920-92E81.
99yam40
I am going fishing with him in the morning and will ask about his motor and parts
the 0 at first of 031029 says it is 2000 not a 1999
can you give the other numbers before the 031029
this is what i saw when looking
2000
15002-030001
15003-030001
15003G-030001
DT 150STCLY
DT 150TCXY
DT 150TCXGY
cannis32
Interesting: here is the full serial # 15002031029.
Thanks for your responses and help.
99yam40
sorry I forgot to ask him,
I will call him to see what motor he has parts for and get back to you today.
I called and he has parts from a 97,
he thinks it will fit.
I will send you a PM with his e mail address so you can get in touch with him and see what all can be worked out
by the way where are you located?
99yam40
Cannis32 did you have any luck with parts ?
He said he sent an e mail with pics but never heard back from you
