First thank you to all that helped getting my motor running.
I changed the amp box to a coil and condensor and now the motor starts and runs great as long as I keep it choked when it is not choked it dies. It idles great and starts great tho. Carbs were cleaned and all the gaskets replaced.
<br /> Also how much water should be comming out the the water output with the engine at idle before a water pump is replace
