Chonk
- Joined
- Jul 27, 2010
- 17
I just purchased a 1989 Sea Ray 160R. My first boat, and although the boat is in pretty good shape all around, there was a spongy board that covered up the gas tank. Tonight was the first chance I've had to pull it up and look around.
It looks like the rot has been contained to just that board and the support pieces that it rested on.
My questions are:
? In the seam between the tank and the sidewall and under the brackets that hold the tank down, it was sealed with a piece of duct tape all around (see picture 1&2). I've cleaned up the tank and walls, but wonder if new duct tape will stick or if there is a better way to do this?
? I have to replace the supports which seem to be 1x1's and then replace the board itself. Do I have to use special wood for the 1x1's? Do I have to glass them? It doesn't appear that these ever where.
? What about the main board that covers the opening. It appears to have been glassed from the beginning. (see picture 3)
? And what is the purpose of the other small board with the hole cut in it thats attached to the underside of the main board for? (picture 3)
Thanks in advance. This seems like it should be a fairly easy thing to do myself. Am I right or wrong?
My questions are:
