evinrude bayliner
- Joined
- Apr 2, 2007
- 41
I recently purchased a 70s model 85hp v4 evinrude outboard. The motor has been sitting for a few years. My guess is the last time it was run was in 2002. I changed the plugs, checked the compression, replaced the fuel filter,water pump impellar, thermostat and changed the lower unit oil. I took the boat to the lake this past weekend twice. The motor ran great all day saturday. On Sunday as the day was whinding down we were cruising at WOT when suddenly the motor stalled. It fired right back up and we cruised another twenty minutes at WOT when it stalled again. When I fired the motor up again to get back to the dock it would not start without using the choke. I also noticed that the motor uses alot of gas. It burns about 1 gallon at Wot in about 15min. This is a 17 foot bow rider with 3 people. Does this amount of fuel being burned sound right. The motor idles fine at all rpms and does not surge at all. What else should I look for that could cause this stalling problem?
Should the carbs be check out? Any info would be a great help.
