2+2 125hp 2001 make, will never keep idling at all
BryaninFL
Been trying to get this motor to keep running but with no luck.
Carbs were cleaned, motor has correct spark.
Fuel pump rebuilt, had ethanol debris in it.
Adjusted the idle circuit screws on the top two carbs with not much luck.
Holding the warm up throttle to 1500 rpm's and than adjusting the screws till the popping went away helped to a point.
Put back to nuetral she still will not keep running, other idle adjustment screws make no difference.
I even adjusted the idle circuit screw on the second carb all the way closed and that didn't even change the running, maybe that carb has issues, i would believe that would have done something by turning that all the way in.
Or possibly the trigger is faulty.
Help please?
BryaninFL
Re: 2+2 125hp 2001 make, will never keep idling at all
I guess not
figured it out anyways it had bad rings on #2
