2.2 HP to 3.3 HP conversion
kmrmike
I have a merc 2.2 HP(1985) and would like to convert to a 3.3 HP to get boat to plane...Any Help would be appreciated...Mike The 11 foot sailing dingy weighs 125lbs.
Yepblaze
Re: 2.2 HP to 3.3 HP conversion
1st off getting a 50% increase in power from any motor with some simple modification is like impossible.
And second, making any boat bigger than a toy or model boat actually plane with 2-3 hp just ain't gonna happen.
JB
What YB said.
kmrmike
Thanks for your feedback...but from my research on the 2.2 and 3.3 the bore / stroke are the same as is the reed valves. The only diference I saw was the jetting of the carb and prop???Any thoughts on this?...Mike The 11 foot sailing dingy weighs 125lbs.
Yepblaze
Well you know more than us.
So....
Get busy and prove us wrong.
kmrmike
I was hoping that someone on the forum may have been thru this already...and maybe save me some wasted effort and money...Thanks again...Mike
xxturbowesxx
Coming from someone who knows a little about engine modifications. Most people i know deal with larger engines but what you say may be true and possible but usually not the case.. As much as people talk about a 2.4 merc 150 vs a 2.4 200.. the differences are mostly in the head of the motor and i would guess you would have to at least shave the heads to make the 2.2 a 3.3..Try asking your question at www,Screamandfly.com they have a forum of builders there.
