What kind of carburetor is it? Typically you invert the bowl and adjust by bending the tang of the float where it actuates the needle valve, you make the float paralelle with the bowl gasket surface.
It's a new Carb and or rebulit from a local boat shop just pulled the top to make sure of the float level Looked into the tank thing everthing seems to be Ok. I even tried to run out of a Gas can Just Because Thanks for the Chat I willing to try anything
