2.3 Omc cobra replacement cylinder head?
Bjpyorala
I recently acquired an 88 Bayliner with the omc 2.3 in it. The cylinder head is cracked and I'm having trouble finding a replacement. Does anyone know what year and model ford autos would have had that cylinder head? Or where to find a marine one? the casting number on the head is E6ZE-AB So i'm pretty sure it's the turbo head, but the boat doesn't have a turbo. Any help or input would be appreciated.
welcome aboard
its a ford 2.3 truck motor. hit a salvage yard and look for a ford ranger. nothing special on a marine motor long block other than the brass core plugs, stainless head gasket and the cam profile.
bruceb58
Just hope you don't need an exhaust manifold. Those things are pricey!
Speak
I Had the same problem. First attempt with an 89 head failed as it was cracked as well. The only one i found was an 1985 head off a Mustang. The valves looked obviously smaller but the head bolted up. Engine runs strong and hard and I can hit 40mph if push the boat with just me in it. Anyway, the 1985 mustang head worked for me. Good luck
