1stTimeBoatOwner
- Joined
- Aug 25, 2008
- 4
I have posted on here a few questions and I believe that my previous problems were solved, hopefully! I had a problem were my boat was chugging in idle postion and also a battery problem, where my pos terminal melted while being jumped. I bought a new battery, cleaned every single wire from corrosion and also replaced a cracked solenoid.
I then had the boat out for about an hour and I shut it off. When i went to start it back up, the engine kept turning over even after i pulled the key out. So i put the key back in and turned it a few times and finally it stopped turning over. I drove it back to the dock and tried it again, same thing happened but this time i couldn't get it to stop turning over. I had to disconnect the battery and starter to get it to stop. So i pulled the starter and alternator, just in case, to have them tested. I have not tested them yet put this is where I stand. I have been told that the key switch could be broke?
any ideas. your reponses are highly appreciated.
