Re: 2-4-C Lubricant
I was told at Merc school NOT to use 24C on bearings, even though it says to right on the tube and in the literature. The Teflon in there is in tiny microscopic strands which can cause needles and rollers to slide rather than roll and form flat spots. It was originally adopted to replace all of the greases used. But apparently problems arose and they still offer gimbal bearing/u-joint grease, spline grease, and Special 101.<br /><br />As for wheel bearings, I highly recommend regular axle grease. I used to use special water repellant synthetic marine trailer bearing greases, but noticed a much higher tendency to cause rust. Water that gets in there stays as small droplets which will rust the bearings. With good old cheap axle grease, the water will mix into the grease and therefore not cause rust nearly as quickly.
