2.5 & 3.0 id confusion
Bluestreak1
I have read a couple of discussions on here about how to I'd which motor is which. One says 3.0 has harmonic balancer 2.5 does not. Have an 85 sea ray 2.5 according to the bore size. No balancer. Picked up another replacement engine that appears to have been rebuilt at some point. The tag on the back of the motor indicates 74 thru 77 2.5. It has what appears to be a balancer on the crank with the drive pulley. Any clarification would be appreciated.
Ayuh,..... Welcome Aboard,..... Sounds like it's miss tagged,.....
3.0 has balancer, 2.5 has pulley
3.0 says 3.0 or 181 on port side of block
2.5 says 153 on port side of the block
The 153 has 3.875" bore
The181/3.0 has 4" bore and a taller deck
Bluestreak1
That's why I'm confused. 1 motor is tagged as 74 thru 77 2.5. But it has a balancer. Thev85 motor has the head off .so there's no doubt about that one. Are the cid # in the casting?
Bluestreak1
So according to the RAstamped at the end of the number by the distributor, this is a 140hp 3.0. RA code was used from 74 thru 87.
Bluestreak1
My bad! The RA code was used up to 89 for 3.0s. Looks like maybe a variation in 87! Thanks for the input. Apparently the serial tag is in conflict with the code letters stamped on it.
