boatermarquis
- Joined
- Apr 15, 2014
- 117
I got 1976 marquios with 2.5 omc will crankshaft pulley work on 81 2.5 mercruiser?
I think I just realized something.are both these motors I got the same? I read the mercruiser have stronger crank.so are both these motors iron dukes?
Ok well maybe I'll look for the 4.3 and a matching outdrive.
I like the caravelle.and want to get it on the water.but almost positive block cracked in it too.i see alot 4.3 boats with bad floors.might run across one and switch everything, but now realized mounts probly won't match up.unless I can find good core block 2.5.
that's what I meant to write 140 sorry.So if I do find 3.0 will drive gears make any difference? Can I get different prop to even it out? Are the 3.0 and 2.5 same block just different heads had to ask that?thumpar;43.0074 said:The 3.0l is a 140hp. The 2.5l is the 120hp.
