Hello, <br /><br />I'm not too skilled with motors but want to try and cure this myself. I have a 2.5L omc that misses bad and sputters until it hits about 3200rpm then it all of a sudden acts like it snaps out of it and takes off with less missing and hesitation.<br /><br />There's a slot in the crankshaft pully that I assume would be top dead center correct? I make a mark on that slot and use a timing light to set the timing at -4 BTDC which is what I'm supposed to be at when my tach reads 700rpm correct? Ok, I did all this and it runs like total crap. I set the timing by ear and it runs much better than being set with a timing light but it acts like I described earlier. Will chug til I get about 3200rpm and then act as to pull out of the sluggishness and take off like it should.<br /><br />Any help is appreciated.<br /><br /><br />Thanks
