Re: 2 bbl to 4 bbl swap or rebuild
Chris_P,<br />I'm not trying to hyjack your post, but I have interest in this same mod. I have a '97 350 2brl, which is 210hp. I think this is the same as your '96. From the sniffing around here, I thought that I read somewhere that the 2 brl model went to 250hp when Merc changed the cam and lifters. Also, sounds like from this, there was a head change. Not sure, but thought these changes happened w/'98 models. <br /><br />Northern Eclipse,<br />My asumption to this point was, just changing the intake and carb, but not cam, would only provide a minor improvement. Did you do this mod to a 2brl motor or was this a 4brl swap? From your profile, I suspect the latter, but maybe it was a different boat. It would also make sense given the improvement areas you said. With just a 2brl to 4brl/intake change, I would think the improvement would come at the top end. Maybe I'm relating this too much to car engines, but just the carb/intake change would be maybe 10-20hp increase, but its been awhile. There is much in this water world, I still need to understand. For instance I thought a 600cfm was good for 5-6K RPM in a car, but most 5.7L specs show WOT 4-5K. So not sure how a boat engine gains with carb with more flow, without the higher rpms. OK, I'll put a cork in it!
