Jgraham389
- Joined
- Aug 4, 2013
- 10
I am restoring a 1975 Fiberform Bowrider. It was stripped of everything and the floor was soaked. I have removed all the saturated foam and there are 2 drain holes. One is on the deck level, and the other is at the bottom of the boat. If the whole underdeck is filled with flotation foam, what is the purpose of the lower plug? Or does the Bilge Pump go there? I have a hose with a fitting that I assume the bilge pump went to. If it goes on the deck level, then I know what to do . If it goes on the lower plug level, do I need to partition off an area so the new flotation foam doesn't cover up and put the pump there? Being my first boat and nothing to go by, any help would be appreciated.
