2 bottom bolt loops on y pipe broken
Jakem
I pulled my y pipe and the bottom portion of the two bottom bolt loops are gone. Is there a way to repair just those loops the bolts go through. The rest of the y pipe is in great shape.
76SeaRay
Here's a link to my thread on this issue. Hope this helps.
nola mike
How did they break? Corrosion? How did the bolts look?
Jakem
The bolts look good..no corrosion..none of the rest of the pipe are either and the flappers look new so. I haven't seen the peices in the bilge so must have been like that when I bought it
If there is enough left may still be good
tank1949
If salt boat, you may have difficulties getting it re-TIGED. You may also have corrosion on gimbal housing. Examine very closely. Y pipe may have been incorrectly torqued or just age took its toll. I am surprised boat didn't sink.
Jakem
I was alittle surprised there was never really any water in the bilge. I've had it welded and will check for any other issues before I bolt it back up
tank1949
I assume it still has flat surface after welding???
